Oil and the cold????????????????????
MN.
What is the harm storing oil in a garage that will get below zero in the winter at times?
Not so much the cold but the condensation caused by cold. Diurnal (day/night) heating and cooling, can cause water vapor in the air to condense on surfaces and contaminate oils. This is more of a concern with partial containers, naturally.
If the container is sealed, no harm at all.
Wheeeeeew, seasons must be changing, the hoard of cold weather posts are just around the horizon!
Is it OK to run 100w-400 in Alaska in January?
Ok to run 100w-400? Naw I'd go with 1000w-4000 and use a giant battery. lol
Gelation in oils is both time and temperature dependent. The newer oils "age" more slowly but the effect is still there. I always advocate changing oils every spring (at least). This is even if the car was minimally driven over the past year.
Gelation is generally less of a problem with synthetic oils. This is another advantage (of a few) over plain mineral based oils.
aehaas
