Why is it that no one says anything about pcv systems except for chevron? This is from their site:
Chevron Supreme Motor Oils
Chevron Supreme Motor Oils are premium quality automotive engine oils.
Chevron Supreme Motor Oils SAE 5W-20 and 5W-30 are formulated with ISOSYN® base stocks, a shearstable viscosity index improver, and contain detergent, dispersant, wear control, antioxidant, corrosion inhibitor, and foam suppressant additives.
The high viscosity index of Chevron Supreme Motor Oils ensures low viscosities at low temperatures for easy cold starting and rapid warmup and high viscosities at high temperatures for fuel economy, oil economy, and effective protective films for engine parts.
Their antiwear additives provide excellent wear protection of critical engine parts.
A high level of dispersancy in Chevron Supreme Motor Oils protects against deposit and sludge formation in stop-and-go driving and sustained high temperature operation, and protects against corrosion.
Their excellent high temperature oxidation stability prevents viscosity increase and oil gelling in the crankcase. They keep PCV systems clean to maintain smooth engine performance.
Do other oil address this?
