Originally Posted by JTK
Originally Posted by supton
I think you're right, but I bet if I wanted to, I could. I mean, I typically get 5 years and over 100k out of brake pads; with a bit of careful driving (akin to hypermiling) I bet factory oil and tires could go that distance. But I don't think most drivers would be capable of that.
Not saying that I would, OCD would kick in long before then, even if it's not "my car" I wouldn't be able to go that long on old oil.
I think for some make/models, brakes and tires will go the distance. I know in the case of the late model Subaru and Nissans in the family, rear brakes (pads and rotors) are shot by then. My FIL had them replaced on his last Nissan Rogue before he turned it in for the 2019. Tires were original on that 2015.
In terms of engine oil. I would think after 18-20K miles on the factory fill, the sump would have to be topped up regularly to keep the engine from scattering into bits. I'd guess that even if that car saw 2 oil/filter changes in that first 3/36, it would still lead a long life. That's all your typical rental car is going to see. I've owned several of those w/out powertrain issue.
Had to do the front brakes on Fiance's 2017 Leaseon Sentra with 16K miles two months ago. Can't believe they were worn out to the wear indicators. Neither of us are aggressive enough drivers to wear a set of brake pads that quick.
Rear discs wearing out seems to be normal on everything small with rear disc brakes.
