Noise under acceleration
Car is a Mitsubishi Lancer 1.5L. Engine: 4A91 Transaxle: F5MGA (Getrag 452) The incident has happened twice. With the car moving forward a noise that I would compare with the sound of reverse gear (but more abnormal) could be heard. First time loud enough, while in 1st gear, till I came to a stop. Second time it started like during the first time, but it lasted for a whole day. It could be heard with 2nd and 3rd gears engaged too, but again disappeared. (I rolled down the window and paid more attention this time.) It happens only while pressing the throttle and with the throttle depressed stopped immediately. Any ideas?
Originally Posted By: WyrTwister
Is that an automatic or manual . Either way , check fluids . Just a shot inn the dark .
Manual. The noise was quite loud, so something is going on. But on the other hand it disappeared without intervention.
do you physically feel a mechanical problem with the transmission? I had a 91 Acura Integra 5spd it made a reverse whining sound under acceleration but it was just a bad ground in the electrical system.
Twice 1st gear was stuck, while the car was not moving, and I was not able to disengage it. I'm not sure how I did it. Maybe I rolled the car? I really can't remember. But that was also coincidental. Furthermore, sometimes I can't engage reverse. I have to depress the clutch pedal and press it again, but as far as I know this is common.
its common to reverse and still be slightly rolling when first gear is selected and taking off could just be wear and tear on the gearbox and synchros.
Yes, that's what I'm wondering. Does the sound come from worn out transaxle parts?
Another thing I would like to mention, although it may be normal. When in 5th, the shift stick moves while pressing - depressing the throttle. It does not jump out of gear, but the shift stick visibly moves. That's something that is happening for a long time, if not since i bought the car.
Check fluids . Drain and refill if needed . Look for metal , shiny particles in old fluid .
Had changed it 2 years ago. I had Motul Motylgear 75W-80 (GL4/GL5, but it said it was OK for yellow metals) for a few years and then I changed to Red Line MTL 75W80 GL4. I have the MTL for 2 years now. The car requires 1.9L. I used 2 bottles of MTL which is 1 quart each, so actually 1.89L both, but I don't think that makes any actual difference. The mechanic expected for the oil to reach the filling hole, but it didn't, so he used an allen key to check the level of the oil and he said it was OK. The problem appeared recently. The 1st time it happened was 1 or 2 months ago. No metal particles visible, as far as I can tell, the 2 times the oil was drained.
What is the year and mileage of this vehicle? I'm guessing a worn bearing within the gearbox. Does your long axle have a "mid bearing"? Any sheet metal touching a moving part would sound like a scraping, not a "reverse gear" noise.
Around 70k miles. I have no idea what bearings the gearbox has. The noise resembles reverse gear, but there is some rattling. It happens only when the throttle is pressed and stops immediately when I take my foot off. The higher the revs, the higher the pitch of the sound. And as I said it disappears without intervention.
Does this go away as soon as the clutch is depressed? The Getrag 452 is well know for gear rattle, sounding like a box of marbles go dumped in it, all sorts of noise as they age but none are life shortening. Check the inner CV joint and for loose heat shields and belly pans and check the engine mounts. Pentosin MTF 2 works better than every other fluid I have tried in Getrag and ZF boxes (that require a GL-4), it is a GL-4 fluid. This fluid is the answer to cold weather shifting issues found with some units like VW but is able to handle high summer temps with no problem.
JC1
Is the noise loud on a cold start and then goes away once the motor warms up?
Well, it happens when the throttle is depressed. When I take my foot off the throttle it goes away immediately. But it happens randomly. It has happened twice as far as I can remember. It is relatively loud, making you thing that something is going bad, but then it goes away. I had used Motul Motylgear 75W-80 in the past which is a GL4/GL5 and it actually made gear changes easier and softer. Then I switched to Red Line MTL which has the same performance with the Motul one, but it is a GL4 oil. Probably, I have to check if something is loose too as you said. Also the clutch release bearing is making a whistling noise. It goes away as soon as I touch the clutch pedal, even with the slightest touch. It isn't very loud, but it is noticeable when the car is not moving.
You may just have a throwout bearing going bad.
I hope it is something as simple as that. As I said when the car is not moving a whistling sound can be heard from the release bearing. That's something that is going on for years. I'm not sure though it is the source of the sound I describe in this thread.
A few points related to the transmission issues:
  • The gear stick moves when in 5th. It goes back when I lift my foot from the throttle and moves forward when I depress the throttle. This behavior is going on for years now. I'm not sure if it used to do it since I have bought the car.
  • 1st gear got stuck once again today. I turned off the engine and with the clutch depressed I easily put the car in neutral. With the engine on though it was difficult, if not impossible, to disengage the 1st gear.
Any thoughts about these 2 issues?
Sad to say , but it sounds like you might consider pricing a tranny rebuild or a salvage yart tranny . Or start pricing replacing the car .
