Originally Posted by CT8
Originally Posted by Traction
I've been putting nitrogen in thousands of tires for over 13 years for free. Sure compressed air will work, but other than availability, how is it better? It's not, and all kinds of things are nitrogen charged, like shocks, lift struts, fire extinguishers, etc. Yes the O2, and moisture will eventually equalize in a tire, but it takes a long time, so it helps to start with as little as possible. It really helps with bead seat corrosion especially in the winter, and it leaks down slower too. I have a refrigerated air dryer on my air compressor, but I never fill tires with just that. Dry nitrogen always, with a dew point of like -60 degrees, for free. Every time you top off your tires, you replenish the O2, and water. Oxygen, and moisture are of no benefit for tires, or wheels period.
What about the moisture and O2 on the outside of the tires and wheels?
It eventually equalizes, but the point is to keep most of it out if possible, not start with O2, and water that has to squeeze back through to get out.
