This has been covered many times. Engines that are spec for 0w-20 in the US are often speced one or two grades thicker in other countries. Same engines built in the same plants with the same parts. 0w-20 exists to help manufacturers meet their EPA mandated CAFE targets. Same for LV and ULV transmission fluids.
0w-20 is not a bad oil. Anything that meets dexos1 is a very good oil. For a daily driver. For something that's going to be beat on full time, whether because you're a spirited driver or because you track the car, or haul massive weights in your trailer or whatever severe service you can think of. These applications will benefit from the extra MOFT a heavier grade provides.
Engines operate on a broad range of oil viscosity. Every time I hear someone talk about tight clearances in modern engines I shake my head. The clearances haven't changed. The precision of the machining has. Everything fits better, allowing for less breakin time and better engine life.
Please get your facts straight BITOGers
This is valid data
This is valid data
