New oil: Fuchs TITAN Supersyn LONGLIFE SAE 0W-40
Fuchs 0w-40:
Code:
Density at 15ºC DIN 51757 0,842 g/ml
Colour DIN ISO 2049 2.5
Flash Point, CoC DIN ISO 2592 234ºC
Dynamic Viscosity at – 35ºC DIN 51398 5180 mPas
Kinematic Viscosity at 40ºC DIN 51562-1 74.4 mm²/s
Kinematic Viscosity at 100ºC DIN 51562-1 13.2 mm²/s
Viscosity Index DIN ISO 2909 181
And the 0w-30:
Code:
Density at 15 °C DIN 51757 0.843 g/ml
Colour DIN ISO 2049 2.5 ASTM
Flash Point, CoC DIN ISO 2592 234°C
Dynamic Viscosity at - 35°C DIN 51398 5100 mPas
Kinematic Viscosity at 40°C DIN 51562-1 67.6 mm²/s
Kinematic Viscosity at 100°C DIN 51562-1 12.1 mm²/s
Viscosity Index DIN ISO 2909 178
MSDS on these?
Originally Posted By: BMWTurboDzl
Fuchs 0w-40:
Code:
And the 0w-30:
Code:
MSDS on these?
I've made inquiries.
Also looking for HTHS/NOACK.
They'll provide the data. I've been able to coax such information out of Fuchs in the past. If you can't get an answer, PM me and I'll give you a few email addresses in their support department.
BTW, you can buy this stuff in the US if you don't mind waiting 6 weeks. I've corresponded with Fuchs in the past and they will import it, but not directly to consumers. So if someone has a small business.....
There is an official distributor in Toronto that they pointed me to when I was inquiring about the 5w-40 last time, I'm just not sure if these two grades are available here yet, so that's been a part of my inquiry.
Odd that it's called "longlife" just like the BMW approval, but it isn't formally approved. They also didn't go for VW 502/505.
No "XTL" in the name either...
Nope, the XTL oils don't have a 0w-40 or an LL-01 oil IIRC
They do have XTL in both 5w30 and 5w40 LL-04 oils, which meets LL-01.
Isn't LL-04 low-SAPS though? or at least mid-SAPS? I was under the impression that LL-01 was full-SAPS
Correct
Just an update [sort of] I'm running Fuchs [nee silkolene] race pro 5w-40 double ester in a 1.8T at the moment.
It has made the engine even quieter at idle and seems to stay in the engine as well
I intend to have a lab check a sample towards the end of it's cycle [5000 miles] to see just what's what and to see if it lives up to it's expectations.
cheers
Andy Brown.
