Originally Posted by quint
As far as prefilling a filter, if I were you guys I'd be a lot more concerned about the cleanliness of the filter before I'd worry about anything in the oil. I've done oil changes on maybe a dozen cars in the last year, and on every filter I have been able to wipe away metal flakes from the center threaded section, and a black, dusty dirty substance from the oil inlet holes and accessible interior exposed surfaces. Some of these metal flakes are alarming. Fram Ultras, Kia OEM, Mazda OEM, Purolators, you name it. Every single one of them. I wonder how many people actually think to do a thorough (as possible) cleaning of the filter surfaces before they install it. BITOG people, probably a high percentage. The rest of the world? Probably a very low percentage.
Very good point. It's always good to inspect and clean up the filter as much as possible before installation. Most of the time there will be some contamination on the base plate mounting hole threads. I always clean the threads up. Look down inside the center tube with a good flashlight and look for any debris or anything that looks like it could break off and go into the engine. I use the strong LED light on my cellphone at the store when buying a filter to look down the center tube - better there than at home.
