Ok, so this has been interesting. I am trying to find the Quaker State filter for my 2010 Kia Optima w/ 2.4L. The Quaker State oil filter selector (which is clearly linked from Purolator) says I need a QS14612. The QS14612 crosses into Purolator L14612. However, Purolator's own website says I need a L14459. Wix says I need a 51334 which crosses into the L14459. When you cross the Wix 51334 into Fram as a double check, it says that the Wix 51334 is a motorcycle filter, PH6010A! When you cross the Purolator L14459 into Fram (again as a double check) it gives you three options!!! It says PH3593A, PH9688, PH6811. These all cross into different Wix, Purolator and Quaker State filters.
If you cross the Wix 51334 into Quaker State, you get either QS14460, QS14461 or QS3593A.
Holy cow this is CRAZY!!! Nobody agrees across brands when double checking things on the cross reference sites.
Purolator is CLEARLY the source of the Quaker State oil filter look-up website and they do not even agree with the Purolator filter!
I was planning on getting several Quaker State filters while they are on sale but I guess I will stick with my L14459 filters as at least Wix & Purolator agree on this being the correct filter.
