Whenever some entity claims an association with the military, you always need to read the statement closely. Note that the military tests a lot of things and consequently rejects most of them.
Just because it was "tested" or "developed" by the military doesn't mean it was found useful or subsequently was adopted for some use. Testing is just that, to determine efficacy. I can "test" water in my engine as a substitute for oil.
Here is the statement on their website, read it closely. It actually says nothing about whether it was ever used by the military. Also note that such claims as this may be referring to a use that is completely different than the one for which the website is selling.
Quote:
MILITARY TOUGH, MILITARY-TESTED
WHERE MISSION IS CRITICAL, FAILURE IS NOT AN OPTION.
In the heat of combat, machinery must perform under pressure. It must take the heat, literally, and operate at temperatures most machines never reach: from -42° below to 356° F. Equipment failures can cost lives and millions of dollars.
Working in conjunction with the military and with Boeing Phantom Works, NanoProMT is engineering product specifically designed to meet strict requirements and rigorous demands of cutting-edge institutions. And we’ve been put to test, undergoing extensive lab- and field-testing that has led to military-grade formulas being applied to all NanoProMT products.
In fact, looking at the way it is a carefully crafted and worded statement makes me believe it is intended to obfuscate not inform.
