Mystery part on a 2008 3.0 Ford Duratec
Atlanta
Notice the hose on the left side to which nothing is attached and has a cracked gasket and a mystery spring. Might someone know what it goes to? Thanks
The piece in the center of the picture that's kind of rust colored is 100% a direct ignition coil boot. There is a spring that goes in the center that's the contact between the coil and the spark plug. I assume that's what you're talking about without any more clarification.
Well, the mystery has been solved Michael, you are correct, it was an ignition coil. The spark plug even blew out and damaged the head When the shop called to tell me what it was I was told "Sit down and get a beer"
So, after 16 years and 214 k miles "That's all folks"
