About 6,000 miles ago I put in PP & a new Wix oil filter.
A day ago, I noticed an oil spot showing up on the garage floor.
Looked around and found oil around the filter and found it a little loose!!
It didn't start leaking until 6,000 into the run. First time ever I've seen a leak like that...
Are the Wix known for loosening up or has this happened to you with those or others...??
