Good Evening - I am trying to reanimate 2 riding mowers stored for years with a full tank of gas. One is Kohler powered and one is a Briggs. In both cases,the gas leaked into the oil and filled up the crankcase. Both mowers have a solenoid on the carb float bowl that should prevent this. I plan to install a fuel cutoff valve on each mower. Is this common? It seems the fuel leakage would be a fire hazard if the mower is stored in a garage.
Thank you in advance for any advice
