Originally Posted By: oilpsi2high
Definitely making a pit stop at the hardware store on the way home.
This is war.
Yes it is.
Try a multi-pronged approach.
It may take time, but it will make a difference.
Exterior:
1) Do not feed the birds, they knock the seed to the ground (for mice to find).
2) Set Traps outside with peanut butter. I buy the 'plastic' ones at Home Depot (safe/easy to use).
Note: Check and discard dead mice daily.
Note: Keeps traps clean and with fresh bait (do every 3 days).
3) Mice like to crawl under plywood, logs or railroad ties (clean up your yard).
Outside, I like to place the 'green colored' poison cubes you can buy.
4) Seal any exterior holes in house (1/4" and larger).
Interior:
1) Don't leave food laying around.
2) Set same 'plastic' traps as used outside
3) Use Glue traps
Nobody is accusing you of being a slob.
With an old house, could happen to anyone.
Keep a List of each day you caught mice, inside & outside and how many.
Eventually, you will go longer and longer before trapping any.
Careful this Fall, the mice may want to come inside to stay warm.
Good luck.
This is war.
Yes it is.
Exterior:
Interior:
3) Use Glue traps
Good luck.
