Read what JAG said again. Cold engine/hot oil = low wear. So the clearances inside the engine are not the issue but the temperature of the oil iteself. It also bears mentioning that we are not talking the time it takes to get lube flowing during the actual start but the ability of the already-flowing oil, when cold, to lubricate and protect properly. In other words, correct me if I'm wrong, the only real variable that can account for the difference is the chemical properties of the oil at different temperatures. Not even the physical properties of the oil can be included as a variable because different viscosities showed the same amount of wear. Also synthetic vs conventional showed the same amount of wear.
