What’s the difference?
In addition to ASTM D2896, the Total Base Number of a lubricant can be tested by the procedure
detailed in ASTM D4739. There are subtle, yet important differences to consider when looking
at Total Base Number data from each. Technically speaking, the primary differences between
D4739 and D2896 are D4739 uses hydrochloric acid as the titrant and D2896 uses perchloric
acid. In addition, they use different titration solvents.
What does ASTM say?
Because hydrochloric acid is weaker than perchloric acid, D4739 is less effective than D2896 in
titrating weak bases. This can result in what ASTM refers to as a “falsely exaggerated” or
sometimes even “falsely understated”. For these reasons, ASTM says:
When the base number of the new oil is required as an expression of its manufactured quality,
Test Method D2896 is preferred, since it is known to titrate weak bases that this test method may
or may not titrate reliably.
What ASTM is recommended for use on new oils?
When the base number of a new oil is required as an expression of its manufactured
quality, the test method D2896 is preferred, since it is known to titrate weak bases that this test
method may or may not titrate.
What ASTM is recommended for used lubricants?
When the base number of in-service or at-term oil is required, D4739 is preferred in many
cases, specifically for internal combustion engine oils, weakly basic degradation products are
possible. Test method D2896 will titrate these, thus giving false value of essential basicity. When
a loss of a base number value as an oil proceeds in service is required, then test method D4739
should be used.
