Originally Posted By: kschachn
There's little evidence that doing much of anything will void your warranty in regards to oil, but at the same time your resulting mixture has no guarantee meeting any spec whatsoever. The individual oils with their specific additive packages meet the listed specs, but now you are the blender, not them.
This is false. Mixing oils you will still achieve the minimum spec that either oil has. "Guarantee" has no basis here, no manufacturer will guarantee anything that is not 100% their product. Guarantee has no basis in real world either, can you wait till an engine fails and make a claim that any brand will reimburse you for? Usually no.
So, don't mix generic junk with high quality oil and expect high quality oil specs. Mix high quality oil with high quality oil and expect high quality oil specs, of whatever viscosity is determined by the ratio of the two mixed together.
There is nothing wrong with mixing oils and ironically, it is foolish human limitations that results in our rounding off viscosities to 5 or 10 number increments. The difference is slight, perhaps not enough to bother thinking about, but the truth is that in any season with any vehicle, the absolute ideal viscosity will seldom be one that falls on a particular 5 or 10 rounded off number.
Granted that is more effort than will bear fruit for the average consumer in a climate with variable weather, but for a fixed industrial use, it can be calculated what the ideal viscosity is and it's got a decimal point, isn't at all a number rounded off to a 5 or 10.
