The Critic
Originally Posted By: Trav
That's unbelievable, what are they doing? Selling high dollar parts for a failed piece of rubber I guess.
That's almost as bad as GM/Opel that welded the U joints cups in and you had to buy a complete 2 piece drive shaft with center carrier bearing or so they thought, they didn't count on mechanics using Ford joints with inner C clips.
No other Toyota model uses the same bushings?
Toyota does not sell any bushings separately.
However, I did some research today and learning something new.
Moog sells part #K200912 as a "problem solver" bushing for the 10-17 RX350/450, 01-15 Highlander, 09-15 Venza, 04-10 Sienna, 09-15 Venza and 02-12 Camry Front LCA Applications. This is a ball-and-socket design which replaces the traditional rubber bushing:
http://fme-cat.com/LiveDocs/Control Arm Bushings_Sheet.pdf
http://fme-cat.com/overlays/part-detail....0CAMRY&vin=
I checked multiple aftermarket catalogs and confirmed that the 2004 Highlander V6 uses the exact same control arm as the 2004 RX330. In fact, Moog specs the same RK620334/RK620333 LCA's for both vehicles. But for some unknown reason, the K200912 bushing is only listed for the Highlanders; the RX is missing from the supported applications list. I think it is an error.
So, I am going to order a few sets of these K200912 bushings and try them out. They are only $20/bushing and they are something different (hopefully improved) than the generic offshore bushings which are otherwise available.
