Didn't you just get this truck? I told you not to do it.
It’s an old truck it’s going to have issues. It’s still a cool old truck that I’m glad I bought. It’ll get ironed out and be great.Didn't you just get this truck? I told you not to do it.
Doh! I said "timing light" but I meant "test light."If it's randomly misfiring, you should be able to pick it up on the plug leads using a standard light, and this will show whether it's only happening on a specific cylinder/cylinders or if it's all cylinders affected, pointing to the trigger (which also controls injector pulse).
If, as you note, you want to test the sensor signal itself, you can't use a standard timing light, but you can use a multimeter, low current LED light, as you note, or, a scope (most preferable of course, to see the waveform).
The iac on my cavalier sits above the intake throttle body and has a small hole. I took a long brass brush and cleaned out the buildup. You'd be surprised how much accumulated.High LTFT at idle only? Have you checked the Idle Air Control valve? Try unplugging it at idle and see if the idle changes. Also take it out and check and see if it looks gunked up. Maybe there is some carbon or grit not allowing it to close fully, allowing too much air in at idle.
There was a ton of crud in the IAC channel in the intake of my daughters 4.0l Jeep. The valve was pretty sticky, too.The iac on my cavalier sits above the intake throttle body and has a small hole. I took a long brass brush and cleaned out the buildup. You'd be surprised how much accumulated.
So the fact that your fuel trims clean up off idle is typically a sign of a vacuum leak. Spray around your intake manifold with water or brake clean and look for a change.Egr didn’t fix the issue.
Long term fuel trims at idle are +25 when you get the revs up some they get closer to 0. Usually +3-7 which is pretty decent I feel like. So I’m unsure of why at idle the ltft are so far positive.
YesCould this be as simple as a vacuum leak???
yeah acceleration isn’t a problem sometimes full throttle it’ll spark knock though. So obviously some issues in that regard but it very much drives decent. I suspect fuel pressure regulator is to blame for the fuel pressure.Low fuel pressure can affect fuel trims as the ECU has to command extra beyond what it expects to need to. My manual says a 4.9 wants 50 to 60 psi key on engine off.
That said, poor fuel delivery usually exhibits better running at low fuel demands like idling and worse when you're accelerating.
You are low on the front tank and borderline on the rear. Specs call for 30-45 psi at idle. The pumps are weak. Pressure should go up when the regulator's vacuum is removed with a healthy pump.. New means nothing if junk fuel pumps are used. OEM, Bosch and Delphi are the only good ones. In that order.Tonight I got some time to dig into it more and really focus on it.
Fuel pressure from the front tank was 30 rear was about 40 both running. I replaced the fuel filter and no change. Koeo front tank is around 25psi and rear is 35 or so.
Strange since the front pump and tank is brand new.
Pulled the vacuum line off the regulator and no change in pressures but it doesn’t leak fuel. So I’ve narrowed it down to fuel pressure but why I’m still not sure. The other day when I checked fuel pressure it was 40 and I didn’t go any deeper thinking that was an acceptable reading.
Unhooking the vacuum line didn’t change anything. I used a Delphi pump so I would be surprised if it was bad.You are low on the front tank and borderline on the rear. Specs call for 30-45 psi at idle. The pumps are weak. Pressure should go up when the regulator's vacuum is removed with a healthy pump.. New means nothing if junk fuel pumps are used. OEM, Bosch and Delphi are the only good ones. In that order.
The regulator actually keeps the pressure from going too high, so if it's not leaking , it's ok. . That's why the pressure should increase by disconnecting the regulator's vacuum. You can check for a weak pump by disconnecting the regulator's vacuum and monitor the fuel pressure as you goose the throttle. If the pressure drops a lot (10 psi or greater) then springs back up, the associated pump is weak.Unhooking the vacuum line didn’t change anything. I used a Delphi pump so I would be surprised if it was bad.
Also fuel pressure specs seem to differ some depending on where I look.
Seems unlikely both pumps are weak especially when one is brand new. I guess it’s possible though. What about the fuel pressure regulator?
Correct me if I’m wrong, I am currently looking at a wiring diagram and trying to fully understand the system. What about the fuel tank selector valve? It says it’s on the left frame rail. Should I check and make sure I have good voltage there? Is it possible it’s restricted?The regulator actually keeps the pressure from going too high, so if it's not leaking , it's ok. . That's why the pressure should increase by disconnecting the regulator's vacuum. You can check for a weak pump by disconnecting the regulator's vacuum and monitor the fuel pressure as you goose the throttle. If the pressure drops a lot (10 psi or greater) then springs back up, the associated pump is weak.
I go by what my factory manuals state. For 1987-1994 300's the idle pressure should be 45-60. On 1995-1996 the pressure should be 30-45 psi at idle. 1996 was the last year that beast engine was made.
You have a lean miss as indicated by your highly positive long term fuel trims. Don't pay much attention to the short term trims.The computer is adding a lot of additional fuel to maintain proper air/fuel mix. Low fuel pressure, stuck EGR, exhaust leaks upstream from O2 sensor, major vacuum leaks or bad data from a sensor.
