Orangepeel
- Joined
- Oct 16, 2023
- Messages
- 321
The regulator actually keeps the pressure from going too high, so if it's not leaking , it's ok. . That's why the pressure should increase by disconnecting the regulator's vacuum. You can check for a weak pump by disconnecting the regulator's vacuum and monitor the fuel pressure as you goose the throttle. If the pressure drops a lot (10 psi or greater) then springs back up, the associated pump is weak.
I go by what my factory manuals state. For 1987-1994 300's the idle pressure should be 45-60. On 1995-1996 the pressure should be 30-45 psi at idle. 1996 was the last year that beast engine was made.
You have a lean miss as indicated by your highly positive long term fuel trims. Don't pay much attention to the short term trims.The computer is adding a lot of additional fuel to maintain proper air/fuel mix. Low fuel pressure, stuck EGR, exhaust leaks upstream from O2 sensor, major vacuum leaks or bad data from a sensor.
Both are from direct hit which do you trust? Hard to verify and properly check things when the information isn’t even confidence inspiring.
