JHZR2
Staff member
This is a skill question, thus why I made it its own thread...
I’m replacing a Good portion of the rear sill plate on my 10 bay garage, as some of it has termite damage. No signs of termites anywhere anymore, but want to get new plate in. The foundation is a block trench type, so I’m grouting 10” L bolts in the right spots to code. A few studs had termite damage going up them, what Ive found to be easiest is to just cut off the studs a few inches up, then sister a new stud right next to it. I may put a piece in under the old stud for more support, tbd... bigger fish to fry.
So, the issue is measuring the replacement stud length. Ive tried to just use a tape, and curve it over at the top, and guesstimate. Ive used the trick where I know the measuring tape body length, and add that to the measurement. Neither are accurate. I end up a little long every time, and then have to shave off 1/16 or 1/32 at a time. Very slow and inefficient. It’s never a lot of material, it’s just that they’re never consistent, and always by a tiny amount.
What is the best practice to measure the length between the sill and the top plate? Maybe it will never be perfect; I am starting with rough cut top plates... but I’d like to minimize the rework and trimming to fit. Is this asking too much?
