Originally Posted By: Kestas
Guess again, they're used in small aircraft. If enough particles build up on the magnet a sensor trips the warning light letting the pilot know the engine may be disintegrating, and hopefully give him enough time to land before the engine seizes.
Interesting. I guess you are talking about a chip detector? Those would be in turbine engines that I've seen.
Never seen one in a piston engine. I have seen mag plugs in piston engines but they only tell you something is wrong during the oil change. This is why UOAs are used and very important in small aircraft engines.
I've flown quite a few aircraft and only when I was flying a KingAir did I start seeing the chip detectors. Never had such warning systems in the piston twins (Baron, C414, C421 and Model 76 Duchess) or any single engine plane (C172, Archer, Arrow, Dakota, Saratoga, C210, Bonanza and Malibu) that I've been in.
Maybe I'm getting old (ok I am
) but I don't remember any....
Originally Posted By: Toy4x4runner
SO I'm not hurting anything by upgrading to a mag plug then.
No.
But you really are not gaining anything either IMO. Anything damaging in the sump is already damaged and the sump pickup then goes directly into a filter which will catch anything that could damage the engine.
The oil pump can pump pretty large items with no effect to its life.
Take care, Bill
