M1-212A cut open from F-150 coyote V8
Florida
This filter was used for 12 months and 10200 miles.
2012 F150 5.0 coyote engine.
Oil was QS HM 10w-30.
About 3 quarts was added over that time due to RMS leak.
Same oil went back in with a Fram Titanium 10575 filter.
Everything still looks good. Perhaps the baseplate has some crud on it but still even after 10k not bad. Do you plan on running the titanium for 10k? Does it have the wire back or the new version (non wire)?
Idk which version of the titanium I have but will likely keep it on for 1 year.
Planning to send a oil sample to Blackstone at 5000 miles, then decide how long to run the oil.
...About 3 quarts was added over that time due to RMS leak.....
Hope you got a good supply of used pizza boxes on hand. (j/k).
Filter looks pretty good at 10k mi. fci. I see what looks to be an indention on adbv from inlet hole, but not a functional issue.
Thanks for c&p.
