Patman
Staff member
Here are the latest results from my 2006 Civic, analysis done by Wearcheck Canada:
7,775 miles on oil
Apr 13, 2014 to June 14, 2105 (14 months)
117,825 miles on engine
Mobil 1 0w20
Fram Ultra oil filter
4.0L oil capacity
350ml make up oil
MM was at 0%
Iron 7.7
Lead 0
Aluminum 3.9
Copper 0.7
Chromium 0.9
Nickel 0.1
Titanium 0.1
Tin 0.1
Silver 0
Silicon 17
Potassium 0.7
Sodium 10
Moly 74
Boron 35
Barium 0
Calcium 1075
Magnesium 712
Manganese 0.3
Antimony 0.8
Vanadium 0.2
Beryllium 0
Cadmium 0
Lithium 0.1
Sulfur 1697
ZDDP 15.2
Phosphorus 606
Zinc 660
Oxidation 68%
Nitration 72%
Sulfation 59%
Soot 0
Glycol 0
Water 0
Fuel 0
Viscosity at 40c 38.1
Viscosity at 100c 6.9
VI 142
This is the longest I have gone between changes with this car and I was very impressed with the low numbers. The engine is consuming a bit more oil than it did previously, but not an alarming amount (it was down 0.75L at the end, and since I added 350ml that means it consumed a total of 1.1L this interval but that's not too bad for almost 8000 miles if you ask me)
I put in more M1 0w20 and another Fram Ultra filter, as it is working well so why deviate? I'm going to continue waiting for the maintenance minder to count down completely to zero before changing the oil. At the rate I drive now it will most likely always end up being just over one year's time.
7,775 miles on oil
Mobil 1 0w20
4.0L oil capacity
350ml make up oil
MM was at 0%
Iron 7.7
Lead 0
Aluminum 3.9
Copper 0.7
Chromium 0.9
Nickel 0.1
Titanium 0.1
Tin 0.1
Silver 0
Silicon 17
Potassium 0.7
Sodium 10
Moly 74
Boron 35
Barium 0
Calcium 1075
Magnesium 712
Manganese 0.3
Antimony 0.8
Vanadium 0.2
Beryllium 0
Cadmium 0
Lithium 0.1
Sulfur 1697
ZDDP 15.2
Phosphorus 606
Zinc 660
Oxidation 68%
Nitration 72%
Sulfation 59%
Soot 0
Glycol 0
Water 0
Fuel 0
VI 142
