The argument about LOS diluting the sump's total additive quantity makes sense.
But there's something in LOS that acts as a delivery agent for the regular oil. That little gear gizmo in the stores is kind of neat. You can turn the gears very slowly and instantly see the oil moving around the gears on the LOS side because the oil was already there waiting to be used. The non-LOS oil does not do this, you must crank very quickly to get the oil even near the top gear.
I'm using the LOS synthetic version right now along with 2 ounces of Tufoil. This delivery agent seems to help deliver the Tufoil throughout the engine. Without LOS, the Tufoil seems to lose it's amazing lubricating power because I think it's not moving around the engine like it should. It's so freaking slick that I think the impeller in the oil pump is unable to push the oil around, which is why testing shows that oil pressure sometimes drops slightly after installing Tufoil and other PTFE products. But after installing LOS, I think the Tufoil is able to be distributed properly because the LOS is able to hang on to it. I'm just theorizing here, I know you all say that all additives are garbage, except for ARX.
I'm running Lucas 5W20 syn oil right now, and I think it's not as good an oil as GC. It was very cheap, but next oil change I'm switching back to GC. GC, LOS and Tufoil is my favorite combination so far. My Volvo XC70 runs like a striped ape right now, though it did run better with GC.
