Lg washing machine soap dispenser leaking
Noticed a tiny bit of water leaking from the front of the dispenser . I removed and cleaned the dispenser no luck and took a brush to clean the jets take spray water into the dispenser. The water pressure was also reduced by half both hot and cold .
How old, what part, any pictures?
The dispenser in my Bosch is pretty simple. Is yours some kind of self-metering design?
It's a few years old model wm3500Cw .
Can you plug the lines that take water to the dispenser and switch to pods? You can also toss the measuring cup the liquid stuff comes in right in the machine, just fish it out before you move the clothes to the dryer.
Machine level? Try raising the front some so water tends to migrate rearward into the housing.
Look up inside the housing for any buildup on the nozzles where water sprays down into the cups.
I pulled all the blue trays out and just use pods. The water sprays bounces off those trays and down the side. Mine has completely stopped since removing…
