This too
..but in an effort to more completely answer your question ...
Formula Shell Multi-vehicle ATF
http://www.pzlqs.com/Docs/GPCDOC_X_cbe_24855_key_140002162227_32AE.pdf
The spec's are identical for PZ MVF AFT
http://www.pzlqs.com/Docs/GPCDOC_X_cbe_24855_key_140002163815_4BE.pdf
..and Quaker State is the same as well.
Mobil 1 works
Mobil 1 Synthetic ATF is also suitable for use in vehicles that specify the following fluid requirements:
Audi G 052 025-A2, G 052 162-A1
BMW LA2634
Esso LT 71141
ETL-7045E, ETL-8072B, N402
Ford* MERCON*, MERCON V, MERCON LV
All 2005 and earlier GM vehicles**
Honda ATF-Z1*
Hyundai SP-II, SP-III
Idemitsu K17
JWS 3309
Kia SP-II, SP-III
MAN 339F, V1, V2, Z1, Z2, Z3
Mazda ATF-III, ATF-MV
Mercedes-Benz 236.1, 236.2, 236.5, 236.6, 236.7, 236.9
Mitsubishi Diamond SP-II, SP-III
Nissan Matic-D, Matic-J, Matic-K
Subaru ATF
Toyota T-III, T-IV
Voith 55.6335.XX (G607, G1363),
Volvo 97340
ZF TE-ML 03D, 04D, 09, 14A, 14B, 16L, 17C
as does Mobil's MV ATF
Approved for MERCON® VApproved for Allison C-4 applications
Exceeds the requirement of the JASO 1-A performance standards
Mobil Multi-vehicle ATF is also suitable for use in vehicles that specify the following requirements:
BMW LA2634
Esso LT 71141
Ford* MERCON*, MERCON LV
Honda ATF-Z1*
Idemitsu K17
JWS 3309
Kia SP-II, SP-III
Subaru ATF
Toyota T-III, T-IVVoith 55.6335.XX (G607, G1363),
Volvo 97340
Texaco's MD-3 doesn't show SPIII as a recommendation. Just DexIIIH, MerconV, and +4
I didn't dwell too long on Red Line's site, but found no specific reference to SPIII.
