Is Mobil 1 75-90 a group three oil?
tooslick:quote:
Originally posted by TooSlick:
Ben,
It's always been PAO based with a sulphur/phosphorus additive system ...excellent stuff for $7.00/qt. It's GL-5/MT-1 rated for transmission use.
Ted
That's part of what I don't understand. I read that and it seems that Mobil specifically prohibits the use of this gear lube in a tranny that is speced for GL4 only. Yet many people say it's okay and have good luck using it. What really throws me, is that I think Mobil's marketing practices are similar to Amsoil's in some ways, yet they back off on this product. I just wonder why?quote:
Originally posted by Ken:
"Mobil 1 Synthetic Gear Lubricant is suitable for all automotive applications where lubricants meeting API Service GL-5, are recommended. It can also be used in rear axles where an API Service GL-4 lubricant is recommended. It should not be used in any transmissions requiring an engine oil or automatic transmission fluid, or GL-4 performance level."
http://dallnd6.dal.mobil.com/GIS/MobilPDS.nsf/26b7 c4b33367a4a086256665004e4266/951b10d046e0bafd852567ba0050ec5f?OpenDocument
That is indeed interesting, thanks George.quote:
Originally posted by GeorgeCLS:
So, one might ask how people are putting GL-4 approvals on oils when there is no longer a valid test procedure or even a rating?? Interesting......
George Morrison, STLE CLS
Because if it's listed on the website people can take that as a corporation endorsing that particular use. If it's just a person, no matter how knowledgeable, if they are wrong, there is no liability to them. Sometimes reassurance is a good thing. Do you really think airport security is that much better than it used to be?? People THINK it is, so it's alright with them, even though insiders know it's still a joke.quote:
Thanks for the clarification George ...that's about the way I remember it from the last time this issue came up.
Why folks believe websites created by software engineers over folks who actually do this stuff for a living always amuses me ...
TooSlick
This is confusing. So someone doesn't get this wrong, The following is quoted from the RedLine web site:quote:
"To protect our transmission, we went with Red Line 75W140NS gear oil, which is the heaviest bodied, slickest lube Red Line would recommend for a syncro-equipped transmission. The "NS" means that it has friction modifiers for a limited-slip diff.
The regular Red Line Gear Oils DO have limited slip additive.quote:
75W140NS - recommended for manual transmissions and non-limited-slip transaxles that recommend 140 WT oils. Can be used in racing limited-slip units to increase lockup and reduce wheel spin. Street-driven rear-wheel drive cars should use regular Red Line 75W90 or 80W140.
