Is Dexron2/3 interchangeable with mb236.14?
Hello, my car is mercedes and i have 4 liters Fuchs TITAN ATF 4134, from my last automatic oil change, which meets only mb 236.14.
Can i use it for transfer case and power steering if manual says:
transfer case fluid- atf dexron 2 or atf dexron 3
power steering fluid- atf dexron 2 or atf dexron 3
or better to buy mobil atf 320 (dexron 3 G)?
IPS systems are rarely ever picky. It could work in the transfer case but I'm not sure, You could try and see if the engagement is good. I'd at least keep it for the PS system.
I know that with older .10 and .12 they did allow dex 3 to be used in the transmission as a substitute but .14 is newer. What does the owners manual say about the transfer case and transmission.
There are some existing threads on this or a similar topic, perhaps one of them will be helpful:
Depending on the year of your MB the 134 fluid is what is called for in the transfer case. Even the vehicles requiring the newer FE transmission fluid still use the 134 in their transfer cases.
