Originally Posted By: Astro14
Originally Posted By: john_pifer
I work at BNA (Nashville), and I watch a few planes take off every day - mostly SW 737s, but also a lot of Delta MD-80s.
The MD-80s are always my favorite to watch take off. I don't know if it's my imagination or if it's a sort of optical illusion, but the rotation and climb-out of the DC-9 variants always seem a lot steeper than the boring 737s. Maybe it's the fact that the wing is set so far back on the fuselage, but when they rotate and take to the air, they seem like they "settle back onto the wing" and that tube is pointed almost 45 degrees towards the sky!
The nose on the MDs may indeed be much higher than the nose of a conventional airplane, but that means little when comparing climb...there are several angles at play here.
First is the angle of incidence: the angle at which the wing is mounted on the airplane. IF the wing is mounted with a lower angle of incidence, then the nose of the airplane is higher for the same angle of attack, which, in conjunction with airspeed, is what generates lift...and that brings us to angle of attack.
Angle of attack: the angle at which the airflow is hitting the wing. Some airplanes fly at a higher AOA at low speed (like takeoff) than others. The 737-800 and -900 fly at a very LOW angle of attack when taking off (and at a higher speed) so they don't hit the tail of the airplane on rotation. Since angle of attack is actually defined as the angle between the air flow and the mean chord line of the wing...we should consider...
Mean chord line: The chord is the line between the leading edge point and the trailing edge point. As flaps are extended, the chord line changes, often dramatically.
Flaps are selected for takeoff, but the degree of their extension, and the design of that wing, varies among airplanes. So, flaps 5 in a 757 gives you good takeoff performance. But flaps 15 or 20 might be needed based on field length, altitude, wind, terrain, weight, etc. The wing has a far different shape at 20 than at 5.
The chord line has changed with each change in flap extension...
So: take one airplane with a much lower angle of incidence than another, and it will have a higher nose on climb out. If the flaps are extended to a greater degree on that airplane, then the mean chord line has shifted, too. Add a change in airspeed and the AOA will be different between airplanes.
It's entirely possible that the nose on the MD is at twice the pitch (relative to the horizon) than the 737 for similar climb performance. Due to differences in the angle of incidence, and angle of attack, and flap setting, the two airplanes may be flying the same climb profile, the same vertical path in relation to the terrain, but at very different airspeeds and pitch attitudes.
https://en.wikipedia.org/wiki/Angle_of_incidence_(aerodynamics)
https://en.wikipedia.org/wiki/Angle_of_attack
https://en.wikipedia.org/wiki/Chord_(aeronautics)#Mean_aerodynamic_chord
Excellent explanation! Thanks!
