Good point. I'm a bit surprised it doesn't have one already, but I'm not sure how old Windstar is.Were they available as an option? If so, the wiring might already be in the car and you would just need to add the switch and release motor in the hatch.
How do i check?Were they available as an option? If so, the wiring might already be in the car and you would just need to add the switch and release motor in the hatch.
03Good point. I'm a bit surprised it doesn't have one already, but I'm not sure how old Windstar is.
Sorry i don't understand the difference. The van has rear window defroster and windshield wiper so there seems to be electrical connections present, if that counts? The passenger doors are also power operated.If it was an option, I wonder if it could be rigged up, via junkyard parts or Dorman. Hopefully it's electrically driven, not a cable--cable is just more work, electrically should just be 2 wires and a switch.
They could have rigged up a cable to yank on the release—or used an electric solenoid. Whatever was cheaper and easier.Sorry i don't understand the difference. The van has rear window defroster and windshield wiper so there seems to be electrical connections present, if that counts? The passenger doors are also power operated.
As it stands the vehicle does not have a release on the inside. It is a mod i am considering.They could have rigged up a cable to yank on the release—or used an electric solenoid. Whatever was cheaper and easier.
You need to take the interior panel off on hatch and figure out if you can tug anything (gently) while closer and if the hatch will release. If yes you can attach a cable with handle to tug.As it stands the vehicle does not have a release on the inside. It is a mod i am considering.
No it does not.Alternatively does the vehicle have a remote release for hatch already anywhere in vehicle or key fob? (Rare option then)
Doubt it unless you touch a button on open. Is the latch or operation mechanical.No it does not.
I guess it's not electrical then?
The only way to open the rear hatch is from the outside when the car is fully unlocked (not only the driver side but all 4 sides).Doubt it unless you touch a button on open. Is the latch or operation mechanical.
Back up a second here. Are you saying you want to be able to open the hatch while you are standing inside the cargo area behind the rear seat? I though you meant if you can unlock it from the inside and then open it from the outside. Why would you want to open it from the inside unless maybe you use the back for camping or something?Hello i have a Ford Windstar and was wondering if it is possible to install a rear hatch switch/release so it can be opened from the inside?
Bingo! I tried to make OP clearer but it was past the time allowed to edit. yes to all,Back up a second here. Are you saying you want to be able to open the hatch while you are standing inside the cargo area behind the rear seat? I though you meant if you can unlock it from the inside and then open it from the outside. Why would you want to open it from the inside unless maybe you use the back for camping or something?
