You are correct, I missed that part.I don't have a work space, I don't have proper tools, I don't have the physical agility being almost 80yo, and I don't have the inclination. I guess you missed that in my original post.
Yes, Anchor is a brand and they are junk. I've used them on two early 90's Cavaliers and both fell apart before two years was over and one car was only driven about 5,000 miles.What are anchor mounts? A brand? A type of mount? I plan to go with Toyota mounts.
When it comes to engine mount always go OE, the cheapies never pay because you'll have to do it again in relatively short order, so not only do you lose the money you spent on the cheap part, you have to buy the right part and go through the often intensive labor to replace them again, it never pays to have to do the job twice.Yes, Anchor is a brand and they are junk. I've used them on two early 90's Cavaliers and both fell apart before two years was over and one car was only driven about 5,000 miles.
I would have but OE doesn't offer them any more for a 92 and 94 Cavalier, at least that I could find.When it comes to engine mount always go OE, the cheapies never pay because you'll have to do it again in relatively short order, so not only do you lose the money you spent on the cheap part, you have to buy the right part and go through the often intensive labor to replace them again, it never pays to have to do the job twice.
For certain things I always buy OE. I'm a firm believer in the adage "The thriftiest man pays the most."When it comes to engine mount always go OE, the cheapies never pay because you'll have to do it again in relatively short order, so not only do you lose the money you spent on the cheap part, you have to buy the right part and go through the often intensive labor to replace them again, it never pays to have to do the job twice.
About 90,000
They are probably the most common aftermarket brand out there and they are junk. You want to get this fixed ASAP as bad mounts put a lot of strain on other parts. I had two vehicles which had their exhaust system and radiator damaged by the enging not staying put when accelerating.What are anchor mounts? A brand? A type of mount? I plan to go with Toyota mounts.
I know on my 11 the top dogbone shows the engine has shifted forward. Also feels like it is thrashing around when taking off, unless if you slip the clutch bad.First off... why does your 2011 Camry need motor mounts? Especially being the 4 cylinder. What are your symptoms?
****, that's way too soon, must be a common thing for those mounts...About 90,000
Labor rate in his area is $200+ per hourThere is about $600 inc shipping for all 4 OE Toyota from an online dealer. $1100 is a lot of labor, way too much. Without the book in front of me I would guess about $400-500 for labor. Find somewhere else.
Wow... Cost of living must be really high there.Labor rate in his area is $200+ per hour
Make sure it is Made in Japan & not China. I have a 1984 Isuzu P/Up, still has the original engine mounts. It's already 38 yrs & counting.I should have mentioned that I plan to use original Toyota mounts.
I'm actually wondering if you should?? 90k miles on the OEM and they're toasted?I should have mentioned that I plan to use original Toyota mounts.
Yes, I should. I don't yet know for sure if "they're" toasted, but I do believe at least one mount needs replacing. I plan to keep the car until , but at least a couple of years.I'm actually wondering if you should?? 90k miles on the OEM and they're toasted?
How long do you plan on keeping the car?
I have no idea, nor do you. I bought the car used, and it wasn't well cared for.****, that's way too soon, must be a common thing for those mounts...
Not sure how one can abuse motor mounts, especially not in a Camry. Could be a fluke, random early failure. or misdiagnosed. Bummer regardless.I have no idea, nor do you. I bought the car used, and it wasn't well cared for.
