I need specs for rebuilding a 14bolt semi float 9.5 axle.
NY
On Tuesday I’m rebuilding my 14 bolt semi floating rear axle. I have all the parts but i don’t have any instructions/specs for the bolt torque or pinion drag or backlash values etc. Where can i find this information for Tuesday? I can’t find anything online.
See if one of your friends knows anybody that works in a heavy-duty truck shop. If they do, see if you can get the info or borrow a manual. Good Luck!!!
The truck is a 1988 k2500 light duty if anyone has access to a service manual. It should be the same instructions for 88-97.
Check the sticky at DieselPlace.com 6.5L TD forum section.
The 6.5L TD uses the same differential.
You may have to dig or become a member and ask the same question there, one of the moderator may reply and point you in the right direction.
Don't ask the D-max section of the forum.
