Patman Staff member Joined May 27, 2002 Messages 26,529 Location Guelph, Ontario Sep 16, 2024 #21 Glenda W. said: Valvoline doesn’t recommend extended drains with any of their oils. Click to expand... While that is true, they do somewhat imply it by having an oil named “Extended Protection”
MrBaumTastic Joined Jan 29, 2024 Messages 267 Location Aurora, IL Sep 16, 2024 #22 Patman said: While that is true, they do somewhat imply it by having an oil named “Extended Protection” Click to expand... Sounds like a solid warranty case to me.
Glenda W. Joined Feb 15, 2024 Messages 4,312 Location At Elevation Sep 16, 2024 #23 Patman said: While that is true, they do somewhat imply it by having an oil named “Extended Protection” Click to expand... I totally agree. Somehow they consider Extended Protection = upper limit zddp and a slug of moly. Extra Protection would be a bit more clear
Glenda W. Joined Feb 15, 2024 Messages 4,312 Location At Elevation Sep 16, 2024 #24 MrBaumTastic said: Sounds like a solid warranty case to me. Click to expand... Back when EP first came out Valvoline had a Q&A. Everyone was asking about extended drain. Valvoline has always been up front in saying they do not believe in extended intervals. Their guarantee fine print says 5k mile intervals. Last edited: Sep 16, 2024
S spasm3 Joined May 30, 2010 Messages 17,979 Location North Carolina Sep 18, 2024 #26 Al said: On my GR86. 4 Quarts Valvoline 5w30 EP and 1 qt. Mobil 1 20W-50 V-Twin Oil. I will do a UOA every 5KI miles. The Mobil 1 seems to do a good job. Click to expand... I thought you posted that you were going to run dealer 0w20 with 2 quarts of the lucas 20w50 motorcycle oil? You have some fascination with mixing.
