Car Craft has a article on a 6.0L LS engine that put out 505 HP and 475 TQ with 10/40 oil at 200 degree engine oil temp.
Switched to Lucas 5/20 race oil and at the same 200 degree oil temp it ran 509 HP with 477 TQ.
The LS did have very high oil pressure, 97 psi with the 10/40 and it still had 85 psi with the 5/20 @ 200 degrees.
They said they are going to pull the oil pump and see why it has such high oil pressure, because running that high pressure does rob HP.
I thought that the HP difference would have been greater than 5 HP and 2 lb ft of TQ going from a 10/40 to a 5/20 oil.
ROD
ROD
