Originally Posted By: ecotourist
We replace ours every 3 months during the heating season. We don't use our cooling system very much so a filter goes for 6 months over the summer.
By the way, I suggest you do a bit of reading about filters. The well known name brand is far from the best value.
The name brand "300 performance rating" filter is only a MERV 6. They cost $8.99 each locally for a 16"x 20"x 1". The name brand "1000 performance rating" filters are about a MERV 11 and sell for $17.89 to $19.99 each for the same size.
MERV 8 - 11 is considered adequate for most homes.
I can get "other brand" MERV 8 filters (ie adequate for most homes and better filtration than MERV 6) 2 for $9.99. And that's what I use.
Two separate technicians have told us not to use the more expensive filters that are too restrictive (that impede air flow too much). We used one of these more expensive filters one time during the summer and the inside unit started getting ice on it the same day that we installed the filter. A technician told us it was the air filter causing the problem. (And he checked the freon level, and it was fine.) So, we went back to the kind we have always used for years (the less expensive ones at the lower end of the filtration/merv scale) ... and the problem was solved (no more freezing up on the inside unit). The tech said that he has seen this problem time and time again, and every time it is a restrictive air filter which filters too well that is causing the problem.
