How often to change oil on snow blower?
On things that I can't live without - I would probably change it. 5 years its due. I am guessing it holds less than a quart, so its not a cost question. Does it have a drain plug?
Yes - it has a piece of pipe from the engine sump with a cap on it leading to a place where it is really easy to place a catch pan to collect the drain oil. This may be the easiest oil change in my entire OPE fleet. It's not a question of cost or effort to change the oil on this machine but more the fact that it sees so little run time. After 40 years of owning snow blowers I can honestly say that I've never run one for ten hours in a season. We haven't had much snow the past few years and this machine may not have ten hours of run time in total. That being said I will likely change the oil at the end of the season after running the fuel tank dry. We still have a lot of winter ahead of us so maybe it will get a real workout before then.
FWIW, when I had my walk behind 2 stage blower, I changed it annually in the fall prior to the snow season. My thought was 20ozs of oil is a minor cost when I needed the beast to move snow. I now have a 2 stage blower for my riding mower. The oil is changed in the mower annually as well.
Just my $0.02
We've had very limited snowfall here the past few years and there hasn't been a really large 24+ inch event since this machine was purchased. I believe it ran once last season plus once so far this season but not at all the two seasons prior. It's due for a change at the end of this season and there is an ample supply of 5w-30 M1 EP on hand. Up until now it was very difficult to see the oil on the dipstick because it was so clean but I can see it now. Perhaps the new mantra should be "if you can see it you should change it."
I change it annually in mine. Snowblower engines are not hard on oil, and don't accumulate many hours (homeowner machines), but they also don't usually get the oil temp hot enough to burn off condensation.
Often when I drain the oil from them there is a significant amount of moisture.
2x, when I do the summer storage routine, I make sure to run it until it gets hot enough to cook out moisture before the fresh oil goes in.
Usually every few years . Depends on how much use . Did O.C. with P.P. 5w-30 ( or was it P.U.P. ? :unsure: ) in late October or early November . .
The first oil change is most important to remove breakin debris, sometimes after 5 hours use. After that, I don't stress too much about the oil changes... every 20 hours?
I don't think I've changed the oil in my Toro 726 in 3 or 4 seasons prior to this weekend. Just haven't seen much use too, but I prepped it to sell so I changed it out.
I picked up a 2015 Ariens Deluxe 28 that got its oil changed as soon as I got it home. Looked like it has also gone a few seasons between oil changes.
Used Pennzoil 5w30 syn blend for both as that's the only 30 grade I have.
I'm retired so I have plenty of time in the fall in Wi.to full service my two Toro's.I use Amsoil,I know it's overkill to change this often,but what the heck.I also get to check that all the machines functions are working properly before it's needed
I use Royal Purple in my Snowblower only because it allows me to see the oil on the dipstick. I run it until it loses the purple tint, and turns brown/black. That takes 2-3 years depending on the seasons. I'm on year 2 now and the oil is a very clear purple, as if I had recently changed it.
I have a 1996 Lawn Boy / 22" / 5 hp Tecumseh. Uses 5W30 synthetic. In 2023, put it away for the winter. Left the 1 yr old oil in it. Original owner. Then, come springtime , went back to the shed to get the riding mower out for 1st spring cut. Noticed a pool of oil under snow blower/ thrower. I was like....What's this all about now ? Pulled machine out, put it off to the side. Cut the grass. Finished that pressing project 1st. Went back to snow thrower. Did some investigating. Diagnosed rear crank seal. Not happy. Gotta split the machine in half to get at it. Oil level was dead empty. Put in 1/2 can of Liqui-Moly Motor Restore, the rest 5W30. Fired her up. Leaked another 1/4 qt, then stopped DEAD. Topped it off with a mix of Liqui-Moly & 5W30. Haven't changed it since. No leaks. I'm happy. Leaving it alone.
I will change both 2011 9 hp Honda 2 stage and 2010 5 hp 1 stage Honda if they were used more then 3 times in a season.
Good for you ! :) You have better machines, ( Honda) anyway, so take care of them. My old 96' Tecumseh engine coming up on 30 yrs. Changed the oil 1-2 x a season depending on snow amount. Have a 1,000ft x 17' asphalt driveway. It was never made for that abuse. Brought it up from my 1st house that had a short driveway. I killed it, no doubt. Dried up the engine seals from overuse. But, it's still going strong, for now. I'll dump the oil if we have a bad 26' season, and put back the Motor Saver. I was shocked that the stuff actually worked !!!!! Not splitting open a 30 year old machine to get to the seal. I'll snap off all the bolts tryin to do that.
Here it is the third week of August, and was just in the garage giving away unwanted lawn equipment. The guy asked me if I wanted to give away the snow blower. I'm still thinking on it. I got it from my son 5-6 years ago, and have gotten it ready for snow every fall. Only issue is, it hasn't snowed in like 5 years. But we'll probably set a new snowfall record if I give it away. I could really use the garage space, and I'm gettin too old to shovel everything. Anyone else have this kind of decision to make?.,,
No, but my 1997 2-stage Lawn Boy is kinda old now ( ya think ? LOL ). Last year it unloaded all of it's engine oil in the shed over the summer, for no apparent reason. Went to go retrieve it and stick it in the garage in the fall, and to my surprise " oh..hello..I'm 20 oz of oil on you're shed floor, nice to meet you " Brought it to the garage, diagnosed a rear main seal on the 5hp Tecumseh leaking. Said to myself " well self, you're too old to split this thing in half to get to that seal....not happening " Went on you're typical BITOG garage shelf and dug out a bottle of AT-205 re-seal , some 5W-30, and sent it down the filler tube. It WORKED !!!!!!!! Great stuff that 205 re-seal. Haven't changed the oil yet, used it for 12 hrs on 2-2025, back in the shed in the spring. Have no plans on changin that oil anytime too soon. Let the sleeping bear lie sleeping. Maybe in 2027 I'll dump the oil and put back some re-seal with it.,,,,,if it's used at all. Getting too old to be blowin an 800' X 17' driveway with a 70' x 70' area down by the garages. Plan on drivin over the stupid snow !!!! LOL It will melt, eventually. No way hiring a plow guy to tear off my seal coating with his heavy, nasty blade !!! Took me days to put that stuff down !!!
