Dial indicators usually have a magnetic fixed base to position the instrument stationary. There might be some kind of swing arm to position the probe onto the moving surface to be measured. In the case of a rotor, I would assume the probe is positioned on the rotor surface while the rotor is turned by hand to measure the runout. The distance the needle moves in the gauge is your runout.
