A long time ago, I was involved with the break-in of a rebuilt motor. Part of the procedure was to start the engine and hold the idle at about 2,000 RPM for 15 minutes, then drop the oil. I noticed that the oil was super hot and really flowed as it drained (carrying out any contaminates with it).
So I added a high idle to my oil change regimen. After the engine is warm, I buzz up the idle to about 2,000 RPM for 3 to 5 minutes, let the idle settle back for 30 seconds then drop the oil. (The 30 second idle comes from a Troy built manual where they advised not to shut down a hot motor to give any hot spots a chance to cool, makes sense.)
With the hot oil comes the opportunity to burn fingers, so along with the latex gloves, here's another possibly interesting idea. I cut a short piece of heater hose, 2 or 3 inches long, that fits snugly over the drain plug hex. After loosening the drain plug with a wrench, push the heater hose on the drain plug and use it as a handle to remove the drain plug.
