How do you lube your oil filter gasket?
Originally Posted by gfh77665
Originally Posted by Tman220
I just dip the new filter in my drain pan just enough to wet the o-ring. ..... Anyone making a big deal between new oil and old oil, just for lubing up the O-ring has too much time on their hands in my opinion.
THIS ^^^
Me too.
Originally Posted by edwardh1
Originally Posted by PimTac
Mine come shrink wrapped and pre-lubed.
is that an oem, or denso?
OEM Roki brand, likely made in a Denso plant.
How's that for confusion?
THIS ^^^
Me too.
Ditto
With the amount of oil that i spill trying to fill my filter, it is already lubricated pretty well before i finish.
I fill filter with fresh oil, when topped off, rub with index finger. My ford filters go straight up and down so easy peasy
I use the drain pans with a "tray" and a separate reservoir underneath.
Rubbing the filter around on the tray and then running my finger over the O-ring(both to spread around and knock off any gunk I might have picked up) has always served me well and my oils come off with only a light push on a wrench to break them loose then by hand the rest of the way.
2 pages of replies in just 2 hours to a question that if I posted would have been called the silliest post of the month. I mean, do you actually think a drop of oil on the gasket, new or used, will in any way make a difference in the life of your engine? Maybe let it drain an additional 5 seconds to get out one more drop of oil to compensate.
Originally Posted by Kira
I carefully extract the sealing gasket and send it to a company in Pennsylvania which "treats" it to a coating which not only helps effect a great seal (never had a leak) but lets the gasket break free when OC time comes.
They say it's better than plain oil.
The price is $11.95. They provide leak proof mailers and pay postage both ways. The returned gasket comes in a sealed, crinkly plastic envelope so you can have 'em ready ahead of time.
How do I get my shiftless son in law in on this money maker? Much better than his present job as a traveling carburetor nild rotation tool salesman.
This is another installment of bored ZZMan question series.
Don't have to. Denso oil filters come with a prelube O-ring seal protected by plastic covering. And it has a torque-stop feature too. Turn it down until it stops.
I was waiting for the post, Should I use a socket or a wrench to remove my drain plug? That'll run a few pages.
Originally Posted by Charlie2015
I rub the old and new oil filters together.
Pardon me sir, but this is a family friendly forum.
We'd prefer if you take your adult-themed posts elsewhere!
Don't give ZZMan any ideas...
