Two ways to do a quick check... no real skills needed.
Measure return air temp, then supply air temp. Your looking for 18-22 degree drop.
Go look outside. With the unit running for a while, the larger wet/cold pipe should be sweating right up to the compressor.
If those are good, don't worry.
If I were you and it leaked, I would consider having the R22 removed and recharge with MO99 after a leak search.
Mixing two refrigerants is not allowed.
