Originally Posted by cknight49090
I haven't had a problem myself I just was asking so I would know how much redline to use if necessary to bring zinc up too 1200 ppm.I have seen a lot of cams being eaten and I can tell you it was from using the wrong oil and or improper break in wrong high pressure lube applied.These where flat tappet engines with higher lifts and spring pressure.
If you are seeing a lot of cams being eaten then that sounds more like a material failure or poor design than a problem with the oil. In what engines have you seen this and where?
Is this only during break-in of a new or rebuilt engine or later on during its lifetime? Is an assembly lube being used during build and a dedicated break-in oil?
