I am informed that one of the reasons that we tend to user lighter oils in North America than Europe is because our highway speeds are markedly lower. There's no need to have oil designed with the same levels of HTHS viscosity, the thought goes, because we simply aren't going to be maintaining speeds of 140mph+ for extended periods of time.
This makes sense to me, as the engine would be putting out vastly more output (and thus heat) at higher RPMs and presumably higher temperatures and tougher shear conditions.
I have also, however, heard that some Toyota owners' manuals specify XW30 oil rather than XW20 if a significant amount of highway driving is done. (I have not personally seen this specification.) I'm now wondering if they might be on to something.
My question is as follows: I drive a 2013 Honda Accord V6, and frequently go at around 80-85mph for extended periods of time. My car normally specs 0W-20 and does not specify a requirement for heavier oil at higher speeds. Does anyone know if the J35Y1 specifies a heavier oil in any other market?
Am I getting anywhere near where it would make any sense to start looking for a more robust oil? I don't live in a particularly hot climate, but I suppose my car might see about 100 degrees rarely. (About as likely as -40, though obviously not on the same day!) Nothing hotter than that, though. I just want to make sure that I have the correct protection for extreme cases, like going on an extended uphill at 90mph with a full load on a hot day with the air conditioning on.
Sorry for being so neurotic about this, but I suppose I would hardly be alone here in worrying overmuch about oil weights.
