I may buy some and give it a shot (the 5W40) - v. expensive though...~$100 for 6 qts!
Has anyone tried it?
B/c it's fun to try new things for you car?Why would you bother trying it? Just because it's more expensive doesn't mean it's better. And better than what? It's not even on MB's approved list or maybe it's under something else. It just says meets or exceeds, not that it's actually MB approved. I would just buy Mobil 1 0w40 and call it a day. Or wait til next year when they have that $10 rebate again.
Mercedes-Benz Specifications for Operating Fluids
The Mercedes-Benz Specifications for Operating Fluids provide you with an overview of the requirements for the operating fluids and for the recommended products. Operating Fluids are products necessary for Mercedes-vehicles / major assemblies, e.g. fuel, engine oil, gear oil, ATF, brake fluid...bevo.mercedes-benz.com
How is that fun if it blows up your car and you pay premium dollars for it?B/c it's fun to try new things for you car?
If we had it down here in the states I'd run it in our Atlas.I'll stick with SuperTech 5w-40, because I can.
Really? They are a forum sponsor...I'm going with it will probably be ok....but...How is that fun if it blows up your car and you pay premium dollars for it?
My only real problem is that there's no way to tell if it's actually better. And if it were better, does it really matter? The car will usually rust out, have some other major system go like a transmission, get sold or get totaled before the engine goes due to the oil used.
Who is bringing the HPL oil?
Already running it. In the Volvo. It is better. Absolutely.Why would you bother trying it? Just because it's more expensive doesn't mean it's better. And better than what? It's not even on MB's approved list or maybe it's under something else. It just says meets or exceeds, not that it's actually MB approved. I would just buy Mobil 1 0w40 and call it a day. Or wait til next year when they have that $10 rebate again.
I think I'll give the 5W40 a go at some point next year.Already running it. In the Volvo. It is better. Absolutely.
Better, higher quality additives. More esters. Balanced to protect seals.
Wayne has over 20,000 miles running HPL in his Durango with very compelling results. Take a look at the discussion in his thread.
Too small a company to get MB Approval, HPL makes remarkably good products. Most of them are formulated for specific industrial machinery or racing needs, but their engine oils are carefully produced and tested, and yeah, they are better than Mobil 1.
Thank you for the discount code.There are a few good things to mention. First there is a BITOG15 discount code which nets you 15% off. Next evidenced by the -71F pour point it is clear to see the utilization of PAO. Further when you factor in the use of Alkylated Naphthalene and ester and star polymers, you can begin to understand why we are not formulated for a discount store.
The oil will do an excellent job. It’s my job to make sure that happens.
Mobil makes a fine 0w40. We are not a good fit for everyone.
For those who share the same philosophy we’ll likely be good friends.
David
I have some cold weather 5w40 CK4 HPL extra to bring makes me think I gotta reorder some for stock.I gotcha. None for Wolf though since he wants to be a party pooper.
One question I have for you - my Sportwagen is tuned/larger turbo/sees hard use. I've used numerous common Euro xW40 VW502 00 oils and all of them end up with a decent drop in viscosity at the end of a change cycle. Will your oil hold up better?There are a few good things to mention. First there is a BITOG15 discount code which nets you 15% off. Next evidenced by the -71F pour point it is clear to see the utilization of PAO. Further when you factor in the use of Alkylated Naphthalene and ester and star polymers, you can begin to understand why we are not formulated for a discount store.
David
This is the area where a Star will provide great shear stability. Not that the OCP we use is bad (as evidenced in WWillson’s Durango). Stars are roughly 3 times the cost of a good OCP.One question I have for you - my Sportwagen is tuned/larger turbo/sees hard use. I've used numerous common Euro xW40 VW502 00 oils and all of them end up with a decent drop in viscosity at the end of a change cycle. Will your oil hold up better?
Pardon my density on this - what is a "star" and a "ocp". Thanks.This is the area where a Star will provide great shear stability. Not that the OCP we use is bad (as evidenced in WWillson’s Durango). Stars are roughly 3 times the cost of a good OCP.
David
