OP- did you search problems with the 3.0 VM diesel? I did a few years back when I was toying with buying a GC with the 3.0 diesel. After reading up on the engine I ditched the idea. There was quite a bit of info regarding problems with that engine. I would read up on it and arm myself if you don't get the warranty honored.
After about 3 seconds of searching again this comment stood out: Ecodiesel 3.0L V6: Known bottom crank bearing issues, known fuel delivery issues (Fiat Multijet), known DPF issues, known oiling issues.... if bored google "Ecodiesel issues"...
There is a ton of complaints and problems scattered on the web regarding the engine.......I'm sure there are plenty of good ones too,[and I'll probably get flamed soon] but I think there's enough info to mount a pretty good case against them!
If I'm not mistaken, the Sprinter engine is not the same as the one you are referring to. Sprinter engine is a 5 cylinder Mercedes-Benz design.
