Hi,
I recently posted that I have a problem with the headlights, got low beam but not high beam, i even get the blue high beam icon on the dashboard. Had it checked, they said it coukd be a wire, switch is good, relay is good apparently, fuse too.
Now, im debating to buy a new car or not, mine is a 2011 cruze with 177000 km. It had his share of ptoblems :
- replaced thermostat 3 times.
- had the transmission removed to had a new torque
converter seal
- hood release cable got stuck and broke
- have a wet spot between transmission and engine,
was there since new, still is even if the seal been
changed.
- battery leaked acid after 5 years
- coolant leaking from a plastic hose connecting to
radiator.
- air bag light constantly on in the dashboard
- trunk release button stopped working
- high speed wipers dont work, only normal speed
- water leakage inside from a loose ac drain, all the
water was draining inside the car
- and now no high beam.
I have an excellent deal on a new elantra 2018 and I still owe a bit of money on my cruze.
Is it worth paying it off, or should I invest in a new car with full warranty? I am tempted by the elantra, very nice car. Put lots of repairs on the cruze and im not done, what should i do?!
converter seal
changed.
radiator.
