HELP! 96 Explorer Location??
WDP
Eastern Pa.
Any one out there put a bypass filter on a 96 Ford Explorer, 4.0 OHV engine with all the standard options? I have a Motor Gaurd but for the life of me can't find a spot top side or under to mount it. I am resonably handy when it comes to this stuff, but I'm stumped. Pics would be nice but a good verbal description may set me straight. Thanks in advance.
WDP
1999
Thanks Mike, i put my Motor Guard up about 10 inches up from your location on the cross bar about half way up the radiator. Needed to remove a little bit of plastic air deflector from the front grill. Real solid place to bolt it and in the fresh air to help cool also. Easy to get to if I remove the flat plastic piece beteen the headlights, 4 screws- 2 minutes. I will add a picture when the weather gets better.
WDP
