I was checking out some bypass filters on the web and the Gulf Coast 01-JR (single roll of TP for a filter) looks like an interesting setup.
I was thinking of putting one on my 4.6L Ford (Crown Vic) as an experiment. I don't drive the miles to justify one (maybe 20K or so per year but I have more than one vehicle) but I'm curious to see what these things do.
The biggest problem I have with bypass filters is the installations alway seem jury-rigged. Oil flow is important and having hoses running all over is not good in my opinion. For inlet to the filter Gulf Coast recommends tee-ing off the oil pressure switch mount. This seems reasonable to me. For the return they expect you to punch a hole in your oil pan and use a self threading bolt. That is ridiculous. If something goes wrong your screwed and you must pull the motor to change the pan or try to weld it on the vehicle.
Is there a better return location on the 4.6L block. Maybe an unused tapped plug or something.
This is why I have never used them in the past. Some of the Amsoil systems return via the oil filler cap. In my opinion this is jury-rigged too but way smarter than punching a hole in the oil pan.
How about some input from you guys that use these things on something other than an 18-wheeler
