I've used 10W30 in summer a couple of times. I started using cheap 5W30 in winter for short drains. Not sure if I'll go back to 0W20 on my wife's '11. Not sure if it matters. I think when I first put in PP 10W30 it might have used a quart over 10k but I haven't seen it do that since. Seems to have no problems going to 10k on an OCI. FWIW, I buy oil filters online by the case off Ebay or Amazon (whoever has a better deal), OEM filters, come with the crush washer too. I don't do the predrain thing on the cannister, I just drop it as a unit. Do have to jack the car up an inch or two to get the drain pan under the car though. Lastly the socket for the cannister likes to stick on, more than once I've gone to change oil and can't find it, only to have to check the last vehicle I changed oil on... Don't over tighten that cannister, I stop turning once I feel it seat.
Only issue I've had with ours is brake pads. The dealer didn't service them properly so one of the rears got stuck and I had to do pads at 60k. I used a cheap set and got cheap results, so did pads & rotors at 100k. Then at 125k the fronts had a pad showing delim so had to do that end also. Otherwise the car seems to be working ok, still waiting to crack 200k to see if it'll be a good car.
