Originally Posted by N Heat
Originally Posted by demarpaint
I made one from a 5 gallon bucket, I posted pictures of it before on this site. Simple to make and it works better than any trap I ever used, including the traps mentioned here. It has a wooden ramp attached to a slot cut in the side, I made it long enough for the mouse to easily walk up. Centered in the bucket about 2" down from the top is a rod with a soda can with peanut butter on it. The ramp is aligned centered to the can, slightly higher, but far enough so the mouse has to jump to it. The mouse goes up the ramp jumps to the soda can, it spins and he falls into the bucket. You can leave the bucket empty for catch and release or fill it with about 3" of water, or antifreeze.
I put the ramp in the corner where I found droppings alongside the wall. Problem solved in short order.
Nice. Ill search for the pic on here. I assume it was a thread about mice?
Edit: found it. Ill give it a try
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4974309/re-more-mouse-issues#Post4974309
Nice find, I gave it a shot and came up with nothing! LOL At any rate it is not my invention, I first saw it when there was a rat problem at the creek at the end of my street. The village used one made from a 55 gallon drum to catch rats, and boy did it catch rats. I made a smaller version. It works like a champ! I'd give it a try.
In the picture in used a peanut jar, which worked quite well. A welding rod goes through the jar, and a few inched from the top of the bucket there a ridges molded into the bucket for strength. About 1/4" below the last ridge about 2-3" below the top pf the bucked I drilled two holes dead center which the rod goes through and the jar sits nicely. It spins like it has ball bearings. Try and distribute the peanut butter evenly in a circle about 1" wide dead center around the jar. When they jump to it they'll spin off and into the pail. I trapped them and let them go in a field a few blocks away.
